Calling
Hems
I purchased a sim card , activated it , installed in phone but can not make calls. Phone shows sim card as a network public mobile
2 REPLIES 2
HI @Hems
if the phone shows connected to PM, then the account was setup properly
what phone do you have? does mobile data work?
try Reboot phone and Reset network settings
hairbag1
@Hems
so you selected a new number ? And paid for your plan...right ?
Try a network reset to see if that helps.
