Calling the US
Adriansmith
Hey folks
Im new to PM and currently subscribe to the $34 unlimited Canada and US plan but am unable to call numbers in the US.
Do I still need to buy the US long distance add-on?
Adriansmith
Reboot worked thanks
HI @Adriansmith
this is a common glitch. Usually a reboot would fix it
and try to call with and without the 1.  Sometimes with 1 works, sometimes without 1 will work
Adriansmith
When calling a US number it tells me I’ve used all of my available minutes.
hi @Adriansmith
you don't, it is all included
you can
1. call Canada-> Canada
2. call Canada->US
3. call US-> Canada
4. call US->US
kb_mv
@Adriansmith You do not need any add ons if you are on that plan. In your app, make sure that the CAN-US plan is indeed the one you are subscribed to. I assume you are dialling 1 with the number, what message are you getting? After the message what happens?
Edit: This is from the terms and conditions of USA calling: Calls made to numbers starting with the following six digit combinations are not included in US calling from Canada and will not be completed when dialed: 712-432, 605-562, 641-552, 605-475, 605-477, 712-775, 559-726.
