Calling the UK using 1000 U.K. Long Distance Minutes
LHolidayB
Hi,
I need to call my student loan company on 00 44 1412433970
When I add 011 to the beginning I still can't get through. I have 1000 U.K. Long Distance Minutes remaining. How do I get through?
LHolidayB
Thanks, the second suggestion ( 01144 14 1243 xxxx ) worked
@LHolidayB
this is how you call UK
drop the 0 before the area code
For example, calling London number 020 8765 4321 should be just call 01144 20 8765 4321 (you can also try +44 20 8765 4321)
so, yours would +44 141243xxxx  or 01144 14 1243 xxxx
@LHolidayB wrote:
Hi,
Please try + instead of 011.  Also, it's 011, not 00.
