06-17-2026 11:48 AM
I just Switched to PM from Bell and I can only call numbers that have already called me, if I try to call a number that has not previously called me it instantly says call failed.
06-17-2026 12:02 PM
hi @Ace16
check if the Bell sim card is removed, and disable Bell eSIM
and make sure PM sim is enabled and set as Primary. Then Reboot phone and click Reset network settings and test calling again
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
