12-09-2020 06:10 AM - edited 01-05-2022 05:41 PM
12-09-2020 06:19 AM - edited 12-09-2020 06:33 AM
@Di3 wrote:How do l check to see how many minutes I’m using a month.
Thanks
Hello @Di3 ,
To do this is kind of cumbersome, unfortunately.
But here is how.
Log into to your SELF SERVE and go to "View my usage".
Here you can choose, last 7 days or last 30 days, or plug in the dates you are looking for from as far back as 90 days ago.
Then view it.
I have copied and pasted pages in the past to sum things up. It is not very user friendly, but it does produce the data.
Edit - ADDITIONALLY, please note:
The "ALL" under "Originating Location" are people calling you and going to voicemail (this does not deduct from minutes allocation).
12-09-2020 06:16 AM
@Di3 , if you are on a plan with limited calling minutes you will see the number of minutes used in the overview tab of your self serve account.
