3 hours ago
I have 50GB data unlimited calling and texting Canada and US. I am going to Hawaii, will my phone work there. Will I be able to call and text to Canada?
3 hours ago
@Terryscell you are correct, wording needs to be more transparent.
We are customers like you. If you want you can use the chatbot to point your observations to Public Mobile directly.
3 hours ago
@Terryscell, its calls and text to and from, and data on both sides of the boarder. My wife was in Florida back in June and was able to confirm with no extra charges and no additional add-ons required. Worked out very nicely.
3 hours ago
Check the wording of your plan. Does it say Calls *TO* Canada and the US, (ie only from Canada) or Calls "FROM* Canada and the US?
3 hours ago
@brendamac the Canada-US package is upposed to work in Hawaii also.
Ensure you have a VoLTE enabled phone to connect. Roaming and and connect to 4G OR LTE.
3 hours ago - last edited 3 hours ago
Yes you can use calling, texting and data while in the USA or Canada to both countries when you have the Canada/USA plan.
You will need to enable Roaming and VoLTE. Also, you may need to manually connect to the AT&T or T-Mobile Network if your phone doesn’t automatically connect to the network.
