12-31-2019 07:46 PM - edited 01-05-2022 08:49 AM
Hello,
it seems that when I call others, my ID comes up as from USA when in fact the number i have selected is from Vancouver area code 236-971-**** I’ve checked my iPhone settings and location is all correct and couldn’t find anything on the community board for a solution. If anyone has a solution please do let me know.
regard,
pat
01-02-2020 04:01 PM
i was originally setup with a 778 number that was based out of Victoria and clients had issues calling me locally and had to dial +1 in the number. i then changed it to a 236-971 under Vancouver and still having the same issue along with my USA ID in caller display. is this all related to the issue i am facing?
01-01-2020 02:28 AM - edited 01-01-2020 02:30 AM
@Trix25 wrote:Hello,
regard,
pat
There really isn't anything you are Public Mobile can do this get this fixed. You could take a number with a different area code. When a phone shows a phone number as being from a certain location, this is often based on a database that the receiver's phone is checking.
12-31-2019 08:10 PM
This is weird! 236 code is not being used anywhere else. Those who see your number as USA, which carrier are they on? If multiple different carrier, then I am not sure where the issue is.
