04-06-2023 02:52 PM
04-06-2023 04:55 PM
Login to account and check to see if your account is still Active. Also if you are on the $15 plan, check to see if you used up the 100 minutes.
Otherwise, there could be an outage in your area. So check the outage map:
04-06-2023 02:54 PM
HI @Martin_t_ma
just saw another post about this
but first, login to My Account using Incognito/Private/Secret browser mode and check if account is active
Reboot the phone once
you can also try changing your network to 3G
If still not work, please submit ticket with CS agent:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
