06-06-2023 01:28 PM
Guys I need help setting up call forwarding on my phone. I tried to input the code for unconditional call forwarding, but it did not work. Is there a specific format that has to be used? Thanks,
ali khalid
06-06-2023 05:27 PM
If Magic Jack uses the internet as a voip service then yes that'll work fine. Will you be hitting a US network enroute?
06-06-2023 02:24 PM
Thank you I was able to activate it. I want to forward my calls to a number on magic jack app. Would that app need to be on another phone. Would this number forward my call even if I am abroad and my number is on airplane mode?
06-06-2023 02:01 PM
06-06-2023 01:59 PM
So how should i enter the code? It says 21+tendigit+’#’+ send?
06-06-2023 01:45 PM
Unconditional call forwarding should work. Meaning EVERY single call to your number will be forwarded to another one.
Any other forwarding will not work if you do not have VoLTE activated. Then all other options become available.
06-06-2023 01:42 PM
I have an iPhone XR. What is PmVoLTE
06-06-2023 01:32 PM
Did you try looking at this yet?
06-06-2023 01:31 PM
@Khalid11 Call forwarding has been having problem for sometime, couple months
What phone do you have? if you have a newer phone and able to use VoLTE, then you can either able to setup the forwarding or ask support to help
If you are using an older phone that is not compatible with PM VoLTE , then coditional forwarding would not work
You can also open ticket with support by messaging to confirm:
