02-03-2026 12:56 PM
02-03-2026 12:58 PM
hi @Vini2026
try Reboot phone and click Reset network settings and try forwarding again
this is the Help articles for the different forwarding options, try different one
https://www.publicmobile.ca/en/get-help/articles/call-forwarding
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
