Call failure
Alysia
I will randomly not be able to make phone calls. It tells me that there is a call failure.I took my SIM card out and put it in another phone and it did the same thing. I can sometimes receive calls but often it says to the other caller that the call failed.
2 REPLIES 2
@Alysia first? what brand and model is your phone?
was it working well before and it just had the issue?? or you just joined PM?  I wonder if it us a device compatibility issue
Depends on your phone, yiu can either use 3G asa workaround or VoLTE , but let us know the model of your phone and will advise from there
HALIMACS
@Alysia
I presume texting in and out works.
You may need to ask the Customer Support Agents to reprovision your SIM/account.
  1. Use the ticketing system for a faster response time. Click here to create a support ticket , typing create ticket, or contact us, to get going,  or,
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
