05-07-2023 03:02 PM
Hello, I am a Public mobile user, so is my friend. But from Yesterday, I cannot call her, and an automated message is playing, "Your call cannot be completed as dialed, please check the number and dial again, 8B1". After that, the call is automatically disconnected while showing the error in android phone, "Invalid number format (incomplete number)". I have put +1 before the 10 digit number, and also w/o it. It makes no difference. When she is calling me, I am getting the call and she can call others as well and I call other other numbers w/o problem. Any idea what's happening here?
06-26-2023 07:19 PM
you have the same problem with any number you called? or just one paricular one?
couple thing to test
Reseat the sim card with a reboot. Turn off the phone, take the sim out for a minute. Then put it back and power up
If issues persists, try to click Reset All networks (Please note this will also delete the saved Wifi and Bluetooth connections, but you can easily add them back after)
If that does not help, and if you have another phone around, move your PM sim card to the other phone. This is force a sim card reprovision and it could resolve your issue
06-26-2023 07:07 PM
Did you ever figure this out? I am having the same issue.
05-07-2023 03:41 PM
glad you got it going. That was going to be all of our next suggestions ! 😎
05-07-2023 03:27 PM
Seems you tried everything so the next step is to contact a CS_Agent to investigate.Submit a Ticket on SIMon Chatbot or private message.
05-07-2023 03:26 PM
@All, I removed the SIM and re-inserted it multiple times, seems like it worked now lol
05-07-2023 03:24 PM
05-07-2023 03:23 PM
@hairbag1 I made the call while away from home, now drove 10 kms to my home, same issue. Changed phones (andriod- andriod) same error.
05-07-2023 03:17 PM
it could be a local issue with Telus network in your area.
If possible, jump in your car and try the call from a different location.
Alternative...try making that call using your PM sim in a different phone.
05-07-2023 03:08 PM
@hairbag1 nope, same error
05-07-2023 03:07 PM
@will13am Nope, same error
05-07-2023 03:06 PM
that would be frustrating, fer shur.
Try deleting her number from your contacts list...then re-enter using the 1 before the number.
It's a longshot.
05-07-2023 03:04 PM
@robb21 , try changing the preferred network type to 3G, see if that helps.
