06-21-2026 10:20 AM
I need a line and eSIM reprovision and cannot figure out where to get actual help from. I was not able to submit a ticket
06-21-2026 10:43 AM
@RylanM wrote:I need a line and eSIM reprovision and cannot figure out where to get actual help from. I was not able to submit a ticket
Hello @RylanM
These forums, which are run by customers like you, is your first point of contact for help as MOST members here are willing to help figure it out instead of just sending you to customer service. If we're unable to help, that's when we send you to customer service.
First, which phone are you using? Have you gone into your settings to confirm the eSIM was downloaded? If you're saying you need "reprovision", to me, that means your eSIM is downloaded. You need to set the PM eSIM as your primary. Was your phone on another service provider before? If so, you may wish to do a network reset on your phone as the previous providers information may be interfering with your connection to PM.
Try this first and get back to us. Let us know what steps you've taken so we can better assist you.
06-21-2026 10:28 AM
Is that a new account? Make sure you disable old sim and only enable PM sim
For help, Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
