CS_Agent
Sandy75
Hi my phone line and internet has not been woring since 3pm my card was withdrawd withe the payment on the 5th i dont have wifi im stuck help please asap thank you Sandra xxxxx  438-xxx-xxxx
Edit by Dunkman: removed personal information
2 REPLIES 2
CSA_PM
Customer Support Agent
Hello @ Sandy75,
As Slusagm mentioned, you’ll need to send a private message and one of the agents will assist you.
slusagm
check outage map and see any outage in your area
https://www.telus.com/en/bc/outages
Adn try Reset network settings on your phone
if you still cannot make it work, ask PM
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.)  Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
