CS_Agent
Pat0617
Activation isn’t letting me finish. I bought a SIM card but it worst take me off the eSIM option
2 REPLIES 2
Dunkman
@Pat0617
Sorry to hear about your troubles.  More details would be helpful.  Do you want activate a physical SIM or eSIM?  Are you using the PM app to complete the activation?
hi @Pat0617 Yes, this error is not uncommon but PM support can help, you can submit by direct message:
