@CS_Agent
StinaB
Service not working data and need to be credited
@StinaB
There might be a outage in your area so check the outage map:
https://istheservicedowncanada.com/status/telus/map
But really we need more details of your issue. It is like saying my car isn’t running…l would like money back for my car.
HI @StinaB
we are just customers here. but you can submit ticket with CS agent and ask for credit
With data not work, try Reset All Networks, usually it helps
and does your phone connecting to PM network? is it new account?
Chalupa_Batman
Hello @StinaB
Could you explain what's happening as we may be able to figure out the problem?
HALIMACS
@StinaB
you’re going to need to provide a lot more details than that for not only us here on the community, but for Public Mobile employees to assist you.
when you log into self-serve, what does the account status say? Is it possible you exhausted your data allotment for the cycle? Try rebooting your device and resetting that network connections otherwise…
If you want to describe it in greater detail here, other users like me, can try to assist. If you’d rather deal with Public Mobile staff, here’s how to reach them:
To contact a Customer Support Agent, send a private message to the Customer Support Agents by clicking here
You’ll need to be logged into your Community account for the link to work.
