@CS_Agent Transfer Number
MLEM87
@CS_Agent
Hello,
It seems that the transfer of my phone number was not done properly.
It needs to resubmit again.
Thank you,
MEGAN
2 REPLIES 2
@MLEM87 wrote:
@CS_Agent
Hello,
Thank you,
MEGAN
@MLEM87  - we are not CS_Agents here.  Click on that hyperlink in your post and click SEND A MESSAGE on the right side, this goes privately to customer support.
@MLEM87
were you not able to receive incoming calls and text?
can you at least make outoging calls?
If you cannot even make outgoing calls, it is a sim provisioning issue, and you need to message support here:
If you can make outoging calls, but NOT incoming, then it is a porting issue.  There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
