CONFIRM IDENTITY can not receiving the 6-digit code
ggfn
I’ve already subscribed to an account, and now I’m trying to activate my phone number, but I’m not receiving the verification code
Missetiene
Hi,
I just had the same problem. After reading through many posts and messaging qith the chatbot ai was on tje troubleshooting  tab and it said togle phone to air plane mode and off.. And juat likw that it worked and all of the activation codes came up (yep all 10 of them, they have a 5 min reset time )
Hope this helps someone else!
slusagm
@ggfn did you just activate a  PM account?  Did you use the browser ?
Or you try you use the PM app to continue the subscription but unable to do so because of the code ?
PM can help with a ticket submission
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
hairbag1
@ggfn
Is there a “Didn’t get code” option ? Have code sent to your email address.
