Bought a USA plan by mistake
kevo970
Bought the 20$ plan yesterday by accident I’m not in USA . Any way I can get the funds back in my account
8 REPLIES 8
TheOldVR
Mistakes happen.... and a few beverages in beautiful Bahamas could add to the complexity of purchasing.
All good, I'm sure PM will help out with a refund...
kevo970
Well I was buying long distance add on and I must of pressed the add on for bundle also . Thought the price was high when I accepted the amount charged . P.s all this was going on while taking care of 3 little ones
@surreyboz wrote:
I am just curious. Buying an add on of any sort is a two step process. So I am just curious how did you accidentally do that?
Speed kills!!Smiley Sad
surreyboz
TheOldVR
@kevo970 wrote:
I wish I was there too !! but stuck here in Bahamas lol
LOL.... life is tough in da Bahamas so no pity for you!!!
kevo970
TheOldVR
Oops... I have a better idea though.... You can head down to see the Raptors game so you can use your PM plan!!!
Go Raptors!
will13am
@kevo970, to obtain a credit back for the errant purchase, you will need to contact the moderator team.  The moderator team can be reached via private message using this link.  Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
