11-24-2018 04:03 PM - edited 01-05-2022 02:34 AM
11-24-2018 04:22 PM
@Anonymous wrote:@Souky123, Just to clarify... The bonus data that is associated with auto-pay requires that you maintain auto-pay. If you disable auto-pay, you loose the bonus.
If subscribers want to use topup voucher instead of cc, they can continue to use topup voucher as long as they enable the autopay with cc. If you add fund to your account with voucher, PM will use the fund in your account first before taking money from your cc.
11-24-2018 04:14 PM
11-24-2018 04:06 PM
Thank you
11-24-2018 04:05 PM
Long as your plan is active.
11-24-2018 04:04 PM
@Souky123, The bonuses will remain on your plan as long as you keep the plan.
