Bonus 250 MB
gloriah
With the $15 plan, it comes with 250 MB of Data. What happens if we go over this data amount? How much will it cost us? Or will our data cut off at that time?
@jadnhm plans are 30 days. So you can go by your payment due date.
jadnhm
Is there any way to view when the usage period starts/ends?
Helpershelper
@gloriah
What’s good about if you decide to buy a data addon is that if you don’t use all of it in 30 days it rolls over until you use it all.
Triguy
PM is prepaid so once you reach your limit then it will stop.
Jb456
It will cost zero.
Once you use up the data it just stops. If you want more data you have to buy a data add-on. 1 gig for $15.
Never an overcharge with PM you only get what you pay for.
kselmak
Just cuts off
You just buy add-on if you need more
