Block someone from messaging me
Melissa_dawn
New in Town / Nouveau en Ville
Hello i was wondering if anybody knows how to block someone from texting you
Naepalm
@Melissa_dawn  look for the number that keeps texting you in your text history. With android you can click on the number and a menu will come uo to add them to your contacts or block the number.
cheers
fdrcamb519
@Melissa_dawn
Blocking texts in iOS is easy. For messages specifically, tap the message from the contact you want to block, then tap on their name, which will reveal the Audio, Facetime, and Info options. Tap on the Info option, then tap on the arrow to the right of the phone icon next to their name. Scroll down and select Block This Caller.
gblackma
@Melissa_dawn What's the make and model of your phone?  Thanks.
ShawnC13
Have you gone in and blocked their numbers?  not sure if you are on iPhone or Android but in your settings you should be able to block numbers from contacting you
* I am happy to help, but I am not a Customer Support Agent please do not include any personal info in a message to me. Click HERE to create a trouble ticket through SIMon the Chatbot *
