Block Spoofed Calls
umnikke8
Can I block calls with spoofed caller ID? STIR/SHAKEN is supposed to be implemented. The Telus FAQ seems to indicate that no device will even display the results. Can I opt-in to blocking spoofed calls?
Luddite
@umnikke8  Review of call blockers: https://www.lifewire.com/top-call-blocking-app-for-smartphones-4050085
Public Mobile cannot do this @umnikke8 .
If any blocking, it must be done on a device level. But when numbers are spoofed, you may not really want that particular number blocked on your device.
MrSpock
@umnikke8 it is very hard to block that kind of call usually they move on after a day or two we all get them unfortunately
Timer
@umnikke8
yes you can blocked but them use each time a differenet number to call.
ignore and delete them and never call back to number you don't know.
