10-16-2022 12:28 PM
OK I know nothing about Blackberry phones but I'm helping someone set up their back up phone until they can buy a new phone. What model is the phone pictured? Blackberry Hub?Where the heck is the Sim card tray? Will it work for basic services of texts and calls? How do I navigate it to find the settings? Were they sold locked?
10-17-2022 03:45 AM
Looks like a BlackBerry Leap to me. The Z3 is almost identical, but the radio specs appear to be targeted toward use outside of north america. If you can confirm it's a Leap, it should cover all of the main 3G WCDMA/4G LTE bands used by Public Mobile/Telus. It runs BlackBerry 10, and would still be useable just fine for some basic web browsing phone calls, and syncing email.
But indeed, that SIM card slot looks trashed.. 😞
10-16-2022 01:04 PM
Says it's unlocked. But I agree I don't think it's worth the risk inserting a Sim card.
10-16-2022 12:57 PM
Looks thrashed. With it's limited compatibility and being an antique I think I would give up on this one. Maybe it would work on Rogers 2G.
10-16-2022 12:53 PM
See my edit and photo.
10-16-2022 12:50 PM
The slot should be "sprung" or whatever that term is. Insert and then you press a little more for it to be in. Then you press it again to let it spring out.
10-16-2022 12:46 PM - edited 10-16-2022 12:51 PM
Aha!
Blackberry Z3 STJ100-1
Barely compatible: UMTS 1, 2, 8
OS 10.3.1.2576
Edit:
Look at that it even shows you how to find the Sim card slot! Connected to my wifi now. But the
Sim card slot looks damaged?
And it needs cleaning?!! I don't know if I want to risk it and damage the Sim card?
10-16-2022 12:35 PM - edited 10-16-2022 12:43 PM
Is it running Android? My immediate guess is KeyOne. Blackberry Hub is their all in one messaging place. Likely have to remove the back hatch. Not likely a tray. Likely a slot. It would work perfectly fine as a talk and text device. Security updates for the internet and wifi would be way outdated. Swipe down from the top. I would imagine they might have been locked once upon a time.
Adding - maybe Z3. That could be problematic for here.
