Billing
Fizzygstevenson
How can I get into my account to add a credit card. I’m locked out.
@Fizzygstevenson following exact what I typed above and it will work
worst case, use Method 2 above
@Fizzygstevenson wrote:
it will not allow me to change password or email.
The process to change the e-mail address requires the use of the ticketing process.
Fizzygstevenson
@Fizzygstevenson you need to try to login My Account and update it yourself at Payment page.  Once you got back in, it is easy
First try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
If you are unable to self reset the password, PM support will be able to help
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
