Billing
DDEE
I upgraded to a different plan and I have been charged my previous plan as well. Help
1 REPLY 1
hi @DDEE
did you use Change Now option?  if so, this is normal , PM will charge you the new plan immediately.  Should use Change on Renewal
but you can ask PM support agent and see if they can help
submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
