02-07-2023
10:55 AM
02-07-2023
11:06 AM
computergeek541
The following un-authorized add on appeared on my account page-why? (100 Minutes Canada-Wide Talk. -$5)
PS. Also another family account shows the same un-authorized deduction. It looks like the accounts were credited $5 because or the last Decembers "refer a friend "promo and then reversed by the $5 debit for the un-authorized add on.
Has this also happened to other members?
02-07-2023 11:53 AM
Good point @Tsawwassen
Indeed, many users who have stuck to one method of access (be it community or self serve accounts) have found an alternate one, sometimes gives options and views which can be very different or unexpected.
02-07-2023 11:50 AM
Never before did I get or perhaps noticed this adjustment -- also not all PM account details are shown on my phone as opposed to my laptop. Nevertheless as you point out, this question may help new customers.
02-07-2023 11:26 AM
@BKNS27- This isn't Tsawwassen's first billing. He's been here a while. But these questions are always good for other newer customers.
02-07-2023 11:22 AM
I was confused about my first billing too with the separate breakup of the plan. 🤔
02-07-2023 11:07 AM
That’s a screenshot from your payments tab, correct @Tsawwassen ?
If so, it’s just an internal breakdown – the total would sum to your plan price.
It’s not a recurring add on purchase.
02-07-2023 11:05 AM
Or as others have correctly pointed out @Tsawwassen , are you looking at the price breakdown of the $15 plan in the payments tab?
Those are just broken down into a service plan/calling component and data component for PMs internal record-keeping type purposes. They really don’t mean a lot to the consumer.
02-07-2023 11:05 AM
Cut and pasting --
| 100 Minutes Canada-Wide TalkDebit | -$5.00Available Funds Balance: $0.00 |
02-07-2023 11:02 AM
There's no such thing as a 100 minute Canada-wide add-on for $5. Where do you see this mentioned? Is it in your payment history? That's how the $15 plan gets broken down there. $10 base and in this case $5 for the rest.
02-07-2023 11:02 AM
@Handy1 wrote:@Tsawwassen Is it possible that you accidentally purchased a add on while viewing them otherwise reach out to support to investigate
There's no such thing as a $5/100 minute add-on. That description matches up with the $15 price plan.
02-07-2023 11:01 AM - edited 02-07-2023 11:02 AM
make sure to click the little refresher icons on the self serve page to ensure you’re not viewing an outdated or cached version.
As far as the add-on, it’s a useless one unless you are on the $15 plan with limited outgoing minutes.
Are you, or were you at one time, on that plan and purchased the add on? If so, it will remain on your account so long as you have an unlimited calling plan now selected.
02-07-2023 11:01 AM
@Tsawwassen wrote:The following un-authorized add on appeared on my account page-why? 100 Minutes Canada-Wide Talk. -$5
You're not being overcharged. The $15 plan price is made up of the that $5 charge added to another $10 charge.
02-07-2023 10:57 AM - edited 02-07-2023 10:57 AM
