Battery drain after APN setting changes
wuleicanada
Hi there,
After I updated the APN settings per instructions from Public Mobile, my Samsung S9+ phone battery started draining very fast?
Is there a reason for that, or is it pure coincident?
Thank you!
2 REPLIES 2
TheSterlinger
Data does drain more then then WiFi but there shouldn’t be excessive battery drain. It should be a coincidence. Perhaps it’s just a battery going bad.
@wuleicanada  Coincidence I’d say . But if you have your phone in 5G instead of 4G/LTE you could  notice the battery drain faster and phone run warmer
