06-13-2026 03:03 PM
iPhone XR eSIM. Voice and SMS work after port. LTE shows but mobile data does not work (Safari shows server quit responding). Please reprovision data on my line.
06-13-2026 03:41 PM
hi @QuinnRead
you removed the old carrier sim or disabled old carrier eSIM?
and PM sim should set with Label Primary. check and Reboot phone and Reset Network Settings and try
06-13-2026 03:07 PM
@QuinnRead wrote:iPhone XR eSIM. Voice and SMS work after port. LTE shows but mobile data does not work (Safari shows server quit responding). Please reprovision data on my line.
Before you contact customer service @QuinnRead , a few questions since nobody bothered to ask.
Does your previous SIM card still work? If so, then the port wasn't completed. Sometimes, if you do a Network Reset, that can help fix things as your old providers info is still there until cleared. Airplane mode on for 1 minute and turn it off and reboot. That will force a connection to Public Mobile.
06-13-2026 03:04 PM
Please message PM
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
