Available funds pay for my plan automatically ?
NuYearNuMobile
So I have enough Available Funds because of referral, bonus,rewards etc.
So as long as there is enough Available Funds,then it will auto renew itself ?
@NuYearNuMobile  - If your account goes into suspension (you forgot to pay), then you would no longer be able to get back your plan (if it is no longer available).  You would need to select from a current/in-marke plan.
@NuYearNuMobile wrote:
But what happens if I forgot to have anough Available Funds. ?
Reason I asked is because under the ''change plan'' options I dont see my current $ plan.
Turn on Autopay and the system will take care of it.
NuYearNuMobile
Alex888
@NuYearNuMobileYes, as long as there are enough funds in your account it will renew by itself on your renewal date. Rewards are added to your account shortly before renewal. If you look at your account around your renewal date it will say expired/suspended, that is normal so just ignore it as long as your phone keeps working.
