04-26-2020 10:48 PM - edited 01-05-2022 11:46 AM
Hello,
I’ve been on auto pay for over a year now with no issues. Suddenly this month my payment did not go through and my account is suspended because PM “could not verify my card information.” This is the same card I’ve been using, and as far as I can tell there should not be any issues with it! What do I do?
04-27-2020 04:00 PM
04-27-2020 03:57 PM
04-27-2020 03:56 PM
Thank you! I checked all possible issues with my card info, so decided to submit a help ticket.
04-27-2020 03:51 PM
@BearFBI hello! I changed my credit card number and its expiration date, then I made a manual payment for the amount I owe this month and it was activated again 🙂 I hope this helps
04-27-2020 03:47 PM
@Anacres What did you have to do to get it working ?
04-27-2020 03:47 PM
hello! thanks for saving me.. my plan is activated again.. stay safe! 🙂
04-27-2020 03:45 PM
hello! thanks for saving me.. my plan is actiavted again.. stay safe! 🙂
04-27-2020 03:33 PM
Thank you! 🙂
04-27-2020 03:31 PM
@Elenalin @Anacres @Cartouche @michaeltian
I'm wondering if you all have the same credit card/financial institution. If you have paper billing check your latest statement for your billing address and any changes that may have been made by a new billing departments software, printer, contractor etc....as mentioned before the change was the billing using ALL CAPS. There can be a very minor change in the spacing in your postal code or your street address. I write my address as: 123 west 1st ave but my credit card is the official post office address : 123 1st ave W . Any minor change can cause this problem.....not necessarily a pm problem but your credit cards verification system detecting a change and rejecting it....just something the human eye is not picking up on but computer software programming is.....
04-27-2020 03:09 PM
@Anacres If you do need to update your credit card after you do that make a manual payment for the amount owing then restart your self serve account there should be a reactivate button press that and hopefully you will be good to go Also you may have to reboot your phone good luck
04-27-2020 03:01 PM
hello thank you so much.. I will try to do it now, I hope it works.....
04-27-2020 02:59 PM
@Anacres Hi one possibility is that you received a new credit card recently if so you must go into your self service account and update your credit card to show the new expiry date
04-27-2020 02:57 PM
I have the same issue 😞 😞
04-27-2020 01:45 PM
I had the same problem today. I had to make a payment with 611 to restore my service. I have no idea why it happened like this when my card has been registered for a long time
Pm is the problem, not us
04-27-2020 06:10 AM
Pay manually first anyway. The payment will remain in your account and you can use your phone while figuring out the reasons.
04-27-2020 03:19 AM
Another member updated their thread yesterday that after double checking the info and re entering the info and checking with her bank she was still having an issue with her card suddenly not being verified. A moderator mentioned it was a was probably a minor change in billing by the bank. The problem was solved by entering the info in ALL CAPS. Additionally a different member discovered that street should have been st. Avenue should be ave. and so on.....
04-27-2020 02:21 AM
@Elenalin, that is why I manually add funds into my account. For that matter, I put enough funds to cover me at least 3 months of my plan?
Have you ever heard of self-serve going down for maintenance? Or maybe, the server goes down? With my luck, it would probably the day it's my plan for renewal. To circumvent this, I add the funds and let AutoPay do the rest. Yes, I am adding more work, and somewhat doing extra for what the purpose is doing, but, why chance in losing my Loyalty Reward for an account suspension. Going on $2 a month for loyalty, I really, don't want to start at the beginning.
Some things can change. Your credit card is due to expired, and thus, you need to update the account with a new credit card and expiry date. And probably the 3 digit code on the back of the card too! ook at your account.
If all looks good, then go ahead and contact SIMon. Chat with SIMon with your issue, so it can create a support ticket for the moderators for you. Click on the question mark at the bottom or here is the direct link to the SIMon too if you prefer too.
Once you think it understands the issue, type submits a ticket. Expect a moderator to get back to you up to 48 hours.
Explain the issue on hand. And they double-check everything.
04-26-2020 11:13 PM
@Elenalin Unfortunately, Autopay can sometime fail, and this will lead to suspension. Try to add funds manually or through 611. To prevent such issue in the future, you may do manual payment even with enabled Autopay.
04-26-2020 10:56 PM
Clear your browser cache/history/cookies. Close browser and open a new browser in incognito/private mode. Also, you can try a different browser.
Enter the credit card address Exactly as it appears on your statement.
Leave the apartment field blank. If needed enter your apartment number in the street address field.
Enter your postal code without spaces unless there is a space on the credit card statement then enter the first 5 digits only with the space.
Note: The credit card will get locked after a few failed attempts. You will then have to contact a moderator for assistance to have it unlocked.
04-26-2020 10:54 PM - edited 04-26-2020 10:55 PM
@Elenalin hello is it possible you received a new credit card recently if so it must be updated in your self serve account since expiry dates are different that could be a possible reason why it wasn’t verified
04-26-2020 10:50 PM - edited 04-26-2020 10:53 PM
@Elenalin try removing your car and re-adding it. goto your self serve account under the payment tab and click manage card.
Make it a practice to manually pay a few days ahead of your renewal date(just add the funds in your self serve) PM will subtract the auto payment from there instead of your credit/bank. you will still qualify for the $2 auto pay reward. you'll avoid all the headaches of your account being deactivated and then not being able to use your credit/debit to reactivate. sometimes the auto pay doesn't work correctly and it won't subtract funds from your credit/bank account.
If you are still having issues I suggest you make a ticket and speak to SIMon by tapping on the ? icon on the bottom right. SIMon will give you suggested fixes and gather the correct information needed to create a ticket in the proper category. Pick the correct categories that suits your issues and then click "submit ticket/click me" to start a private message to the moderators.
https://www.publicmobile.ca/en/bc/get-help/articles/contact-a-moderator
Moderators are available from Monday to Friday from 9AM to 9PM EST and from Saturday and Sunday from 9AM to 7PM PM EST
