2 hours ago
Not sure why a ticket Mismatch, last msg I got from CS agents asked for some info. Big RED Notification box made it seem important.
Can't reply without making out a new ticket.
I do have a few tickets over the last couple of months trying to get this problem solved.
2 hours ago
hi @PnoDiddy
if it has an error about HTML error, usually it was because you pasted something.
What you can do is to select all text from the reply message, delete them all, and the right click and chose Paste as Text and that usually works
