06-26-2024
09:01 PM
06-26-2024
10:51 PM
computergeek541
Been a happy customer with Public 6 years or so. Took a 4G offer last month that included 20 times my previous data which I didn’t really need but the package was less then my previous monthly cost. About the same time the rewards program was changed. My rewards were applied to the first month of my new package but now they are just collecting and not even the amount I was previously earning. I went online and can’t see anywhere that allows me to apply them to my account. I feel deceived.
Any feedback/direction appreciated.
06-30-2024 02:21 PM
@Wyniss wrote:I switched back to the 1 gig plan today and selected “change now” but now I noticed the old plan had renewed already early this morning. So now I have two charges from Public on my card. Will they automatically credit the charge from my old plan or do I have to contact an admin?
When using the immediate plan change option, there is a predominatnt wanring on the screen about how a new plan will be charged for. Unfotunatley, there will be no automatic refund.
06-30-2024 02:20 PM
06-26-2024 09:39 PM - edited 06-26-2024 09:41 PM
this is also available (For New Activations) but has no data included in the package..
edited
06-26-2024 09:34 PM
@Wyniss wrote:Yes, you nailed it. I was on a 1 gig plan. Although with rewards it came to about $28 a month and had local calling only. You say $19 now?
All the plans have Canada wide calling. Also the slowest data speed plan is 4G speed (100 mbits/s). This is what I am seeing as available plan options in my account. You should see a similar lineup in your account. The $19 plan is what you should look at getting.
06-26-2024 09:26 PM
Yah, snookered seems appropriate. I don’t even need the upgrade to Canada wide calling.
06-26-2024 09:23 PM
06-26-2024 09:13 PM
FYI...the old Rewards program was retired and now we just get a few points which can eventually be redeemed for plan renewal, add-on and some contests in future. Now, you pay full plan costs every 30 days but get 5% of those costs in points. Once you have accumulated enough for plan renewal, you must redeem them yourself.
Many customers were snookered into buying larger than necessary plans only to have the Rewards rug pulled out in May...and ...they eliminated many of the "poverty plans" that were popular with us light data users. Here's some info on the new points program...it's not near as good as the Rewards were...but they're something anyhow...
https://www.publicmobile.ca/en/bc/get-help/articles/public-points
06-26-2024 09:10 PM
@Wyniss you can use this link to redeem 15 points for $15 if you have the required amount of points.
Yes, it is a little confusing and will need to get used to. You will be paying more each month and the points will take awhile to accumulate. 😒
06-26-2024 09:06 PM
@Wyniss , you need to go to the rewards portal from the online account to convert points into account funds. The conversion rate is 1 point = $1. However, you can only convert points in batches of 15. As for plan costs, I am assuming that you were on the $25/1GB plan previously. You can get that plan back at $19. Go to the subscription and add-ons tab and check out the available plans. You will see it there. The savings in plan cost will offset any rewards reduction.
06-26-2024 09:03 PM
just wrong timing.
What plan you have now? what level or price you are looking for?
