02-21-2025 11:57 PM
My chip not active, app not open I cant active my chip already paid ! I dont want to be charge montle if my chip is not active and I dont have number phone yet … how I can cancel everything???
02-22-2025 12:17 AM
PM can help to fix the issue, it is just a simply sim provisioning they need to manually work on, just check with them
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
