Answering machine messages
05-29-2024
10:20 AM
05-29-2024
10:21 AM
computergeek541
I usually am unable to listen to my messages. While I am typing in my password, there is a beep that says it is invalid. I have tried setting new passwords. What is my next step?
Service
05-29-2024 10:29 AM
Since you have already tried resetting your password I would open a ticket through the Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
...and then type: Customer Support Agent
Or, if you are having trouble with the Chatbot try sending a private message to:
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 (note: you will need to be logged into your Community account for this link to work)
