06-30-2019 05:41 PM - edited 01-05-2022 05:40 AM
Hi noble members.
Can't send sms but I receive,data works fine.What might be the problem?
06-30-2019 11:24 PM
@MR1155Kagz wrote:Hi noble members.
@MR1155Kagz Try sending the SMS by dialling the number directly not using you contacts. If it works then the issue is with you contacts maybe using an incorrect dialling prefix. Did you come back from a trip recently?
06-30-2019 06:10 PM
Did you check your self serve account to make you have not used up your limit of texts ?
06-30-2019 06:05 PM
Yeah it functions normally
06-30-2019 06:03 PM
No.
06-30-2019 06:01 PM
06-30-2019 05:58 PM
I have the correct SMSC number for Public Mobile
short message service center but still it's not working.I have also tried the APN settings.
06-30-2019 05:58 PM
Make sure your cellphone doesn't add '00' before '1' automatically when you send SMS message.
06-30-2019 05:49 PM
@MR1155Kagz you have to input the SMSC number for Public Mobile
It's a setting (a pre-specified phone number) that allows text messages to be routed properly by the cell carrier. Each cell phone company has its own.
06-30-2019 05:47 PM
Did you recently port your phone# ?
06-30-2019 05:46 PM
No i've not tried using another texting app.
06-30-2019 05:44 PM
@MR1155Kagz What plan are you on? Did you try using different texting app?
