12-24-2017 04:27 PM - edited 01-04-2022 03:10 PM
Is there a way in android (7.0 Nouget) to change the data cycle from 1 month to 90 days?
You can change what day the month begins or ends but I can't figure out how to set the amount of days in a billing cycle.
Thanks
12-24-2017 05:30 PM - edited 12-24-2017 05:31 PM
@canucks4life yes that's another option. I always prefer to recommend Data Witness as it does not collect and send your usage information out to a service for analysis. My Data Manager does. Please see https://productioncommunity.publicmobile.ca/t5/Discussions/How-to-minimize-your-data-usage/m-p/15107... and http://www.mydatamanagerapp.com/privacy-policy/.
12-24-2017 05:27 PM
I've personally used My Data Manager for years now and find it quite accurate.
12-24-2017 05:08 PM
Check it out! Let me know if you need the paid version or have any problems https://play.google.com/store/apps/details?id=com.iwik.datawitnesspm
12-24-2017 05:05 PM
@mimmo wrote:@RobertQc pretty sure there was a free version fo data witness for PM customers.
@mimmo @RobertQc there is, it's called Data Witness PM, courtesy of community member @IWIK. Robert, if you want a primer on Data Witness, check here.
12-24-2017 04:41 PM
12-24-2017 04:39 PM
@mimmo wrote:most people in the forum either use data witness (developed by a PM customer) or my data manager. both are great.
Data witness only $1? Easy solution. Done. I shall skip my coffee today so I can pay for the app 😉
Thanks.
12-24-2017 04:31 PM
