04-23-2020 07:21 PM - edited 01-05-2022 11:44 AM
Hi everyone.
my friend has a Alcatel go flip 4044v. With virgin right now. Looking to switch an I couldn’t model I. Public mobile list all they had was a one touch from Alcatel would a sim work and is there a different type I need to buy.
thanks
don.
Service
06-02-2020 02:15 PM
Thank you.
04-24-2020 04:27 AM
Yes it is compatible with public mobile. There can be some issues setting up the data and MMS on it.....just difficult not impossible. @popping has some experience with it. I'm sure by the time they switch one of us will locate the troubleshooting info to set up the data. Just have your friend come to the community and ask for help if the APN doesn't set up automatically
04-23-2020 11:17 PM
@mellondon, welcome to Public Mobile, a place where we all friends (ssshhhh, don't tell the haters out there), and spread the love (not the virus, though)
04-23-2020 08:34 PM
@mellondon Yes, don't worry. The phone will work fine with PM if it is unlocked. Welcome to PM and all the bests! Enjoy savings.
04-23-2020 08:07 PM
Thanks everyone. Greatly appreciated
04-23-2020 08:05 PM
Thanks so much.
04-23-2020 08:03 PM
Thanks for the helping
04-23-2020 07:53 PM - edited 04-23-2020 08:01 PM
I purchased a Virgin Alcatel Go Flip flip phone for my mother to use with the PM 50/50 plan almost 2 years ago. It was cheaper to get a Virgin version than the Koodo version of Go Flip at that time.
It works very well. 👍👍
I enabled data and restart to get the APN setup automatically. I even sent a photo MMS to her Go Flip as wallpaper.
04-23-2020 07:37 PM
@mellondon welcome to PM. Here's 4 articles on activation and porting and the Refer a friend reward if required:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Stay safe.
04-23-2020 07:26 PM - edited 04-23-2020 07:32 PM
@mellondon @Hi as @computergeek541 said it will work As for the Sim card you will just need a public sim and that will fit it is a tri punch sim and they can be broken down into three sizes Also if you were porting over a number make sure you keep your old account open until port is complete
04-23-2020 07:25 PM
@mellondon Will work just make sure you get it unlocked by Virgin before switching.
04-23-2020 07:22 PM
@mellondon wrote:Hi everyone.
thanksdon.
It doesn't need to be listed as compatible to work. Virgin Mobile customers are using the same network. As long as the phone is unlocked, it will work at Public Mobile.
