Admin- locked out
Darkana420
I locked myself out of my account help
Staliger
@Darkana420 Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
iliketotalk
@Darkana420 hi if you can't get in and tried password reset try contacting a moderator you can do so by clicking the question mark at the lower right corner,to avoid going around in circles with Simon say that you want a human to speak to, a ticket will then be generated briefly mention your issue, you should get a response between 2 to 48 hours a reply should show up in your little envelope in the top right corner
You'll have to wait about an hour or if that doesn't work, you need to submit a ticket at https://publicmobile.ca.ada.support/chat
