08-23-2022 10:41 PM
I’ve been trying to add to my minutes. I can’t make outgoing calls or accept incoming calls. This is the most complicated situation I ever experienced. I added $40 to my account today it said it went through, but still noting.
Add-Ons
08-24-2022 12:59 AM
08-23-2022 11:25 PM
Excellent. Sometimes it's just the simplest of things.
A tip for future payments: you can enter vouchers the same as 611 but using 1-855-4pu-blic. Enter the phone number and then enter the voucher. You don't need to have her phone in your hand.
You can also use real time payments in a few stores. A little extra fee but certainly some convenience. Especially if you gas up at a Mobil. Ask for the payment method, tell them the provider, tell them how much, tell them the phone number. You also don't need to have her phone in your hand.
08-23-2022 11:21 PM
08-23-2022 11:19 PM
It was through #611. I’m doing this for my elderly mother who doesn’t use the internet. Just uses this as her emergency phone when travelling. Turing the the phone off seemed to work. Thank you.
08-23-2022 11:19 PM
Thanks…yes OP replied about 611.
The website is down for maintenance so you can create your account later.
Just wonder how you activated your SIM?
08-23-2022 11:18 PM
for Register You’ll need A valid email address
Your Public Mobile phone number,, To create a My Account profile you’ll need the help of a Customer Support Agent.Chatbot
or tried press on forgot my My Account email address or password
if you don't know the password account, to reset.
after get account set then use browser from computer, clear cache and cookies and use one page inPrivate mode,
To Login Page
you will get verification code by email or SMS
and inserting the 6 digit number and not press anything
just wait a 5 second automatically be login,,
08-23-2022 11:13 PM
08-23-2022 11:11 PM - edited 08-23-2022 11:14 PM
How did you add the $40 add-on in your account in the first place? I assume you create an account.
2FA = 2 factor authenticity.
If you didn’t create an account go to:
https://www.publicmobile.ca/en/on/get-help/articles/create-a-self-serve-account
08-23-2022 11:08 PM
It won’t let me create an account. This is unbelievably and unnecessarily complicated. What’s is a 2FA code? How do I create an account? When I called #611 it told me there was $40 successfully added.
08-23-2022 11:06 PM
When you call 611 does it tell you your balance and your next payment date? Or does it just want money right away? Or does it say it's somehow invalid? And again, do any other services work?
Yes, for the account login you need to go through the support people.
08-23-2022 11:05 PM
When you login to your account after you enter your 2FA code. There is an down arrow dropdown menu then click on Plans & Add-ons.
The website might be under maintenance so try again later.
08-23-2022 11:01 PM
The issue is I don’t have an activated online account. I did this by call #611. When I try to create an account it tells me I need the support of an agent.
08-23-2022 10:57 PM
Since you have no outgoing and incoming calls, try to reboot your phone once
Also, login to My Account and check if your account status is Active
Whrn you are at My Account the main page there would should you your current plan data and minute usage It will also show you all your bonus and paid addons you have . Yiu can also confirm if you have any Available Find, just in case the $40 you out in was only loaded in the account and not used
Also, check Payment Hisotry to confirm if the $40 was loaded and used towards the plan or any addons. Post us screenshots if you don't mind
08-23-2022 10:55 PM
Is your plan active? Does SMS (real SMS) texting and browsing the internet (not on wifi) work?
08-23-2022 10:54 PM
There is no plan add on tab
08-23-2022 10:52 PM
It will be in the Plan & Add-ons tab.
08-23-2022 10:49 PM
How do I see it in my account?
08-23-2022 10:47 PM
If your add-on is shown in your account then reboot your phone by holding down the power button then power off and power back on.
