08-16-2022 12:45 PM
I just purchased an add on, will it start right now or only when I press roaming? How dors it work, its a US roaming add on…
Add-Ons
08-16-2022 06:36 PM
08-16-2022 12:55 PM
US add-on starts right away after purchasing and last 240 hours.
08-16-2022 12:48 PM
For data you need to turn on roaming. It starts right away and lasts for exactly 240 hours. Using the talk in the states is very problematic these days. If your phone can use the old 2G and you connect to T-Mobile and you're in a coverage area of that then talk should work. Some areas can still work on 3G but that's spotty. Data and text should work as normal.
08-16-2022 12:47 PM
@Km00339 it starts right away you must be in the states to use it
