12-21-2020 03:53 PM - edited 01-05-2022 04:34 PM
I recently purchased a data add on. I figured I would need at least 2 g so I selected the data add on twice but only got 1 g credited to me how do I get this corrected???
12-21-2020 04:20 PM
@AmaMasxw1 wrote:Ahhhh yes it does thank you just noticed that!!!
@AmaMasxw1 Did you also add the free holiday gifts from PM of 2GB + 500 international mins available in the add-on selection as suggested by computergeek?
12-21-2020 04:15 PM
12-21-2020 04:10 PM
@AmaMasxw1 wrote:I recently purchased a data add on. I figured I would need at least 2 g so I selected the data add on twice but only got 1 g credited to me how do I get this corrected???
@AmaMasxw1 Multiples of data add-ons show up in one line as mentioned by @kb_mv, ie so you should see 2048 mb in your add-ons.
12-21-2020 04:03 PM
@AmaMasxw1 hi if you still have 15 dollars in your self serve you have to go back in and buy the other gig it is a 2 step process
12-21-2020 04:01 PM - edited 12-21-2020 04:01 PM
@AmaMasxw1 I have heard when you purchase that add on more than once it is combined into one line. Does it read 0/2048?
12-21-2020 04:00 PM
If you believe that you'll eventually use the 2GB, I would consider leaving it. By the way, have you added the free 2GB add-on as well?
12-21-2020 03:55 PM
O btw was charged $30 for it too!!!
