08-25-2020 03:46 PM - edited 01-05-2022 12:56 PM
I tried to add 1gb of data. How do I determine if I did it correctly? I think I may have submitted it twice and been charged for 2gb’s
08-25-2020 08:58 PM
In order to purchase an add on, you first need to ensure you have put enough money into your account to cover the cost plus tax. This is not the same as having your credit card on your file.
Once you have that done, you can then go into Add-ons and click the one you are ordering and submit order. If successful, the screen will say that it is processing. That will take a little time so be patient and then you will get a confirmation message.
Once that is done check your Overview and you should see your Add-on in the summary along with what minutes and data you have remaining in your plan.
08-25-2020 05:29 PM
@Brandonchafe wrote:I tried to add 1gb of data. How do I determine if I did it correctly? I think I may have submitted it twice and been charged for 2gb’s
@Brandonchafe Dial 611 if you don't have a balance and the data is reported under your add-ons then all is good.
08-25-2020 03:56 PM
If you just deposited money in your account and have 30, go ahead and purchase 1 gig. You will have 15 left on your account that will be used against your next cycle.
You could ask them to give it back to your credit card, but it will take about 30 days.
08-25-2020 03:53 PM
To purchase Add-Ons using your Self-Serve account, follow these steps:
08-25-2020 03:53 PM
@Brandonchafe hi buying an add on is a 2 step process first you put money in your account then go back and purchase it go in your self serve under data and add ons to check
08-25-2020 03:51 PM
Hello@Brandonchafe
Lucian here and thank you for reaching us!I will be more than happy to assist you today!
We are here to help you but, before we can do that, I will need you to click on the link below to authenticate so I can proceed to the investigation!
Regards
Lucian PM Mod
08-25-2020 03:51 PM - edited 08-25-2020 03:51 PM
There are two steps to add an add-on
1- add money to your account
2- buy the add-on.
Log into your account. Is there any money in available funds?
Also while in the account. Scroll down to "My data and add-ons".
It will show there what you have.
Let us know!
