12-30-2023 09:54 PM
I accidently added a US add on. I don't need it until January 7th.
12-30-2023 10:37 PM
Thank you for your help.
12-30-2023 10:36 PM
12-30-2023 10:33 PM
@Lorde Then you be fine and won’t need the help of support to rebuy very same one back to back and can jsy do it yourself in your account . Enjoy your trip and happy new year 🥳
12-30-2023 10:32 PM
I wanted to get the 3gb data add on for the first 15 days then an add on with no data and half the price for the rest of the time.
12-30-2023 10:23 PM
@Lorde Also note that to rebuy very same US add on you have to wait 24 hours after the first one ends . Or you need to buy a different US add on . But keep the link to support handy and they can apply the very same add on for you back to back on day 15 of your trip
12-30-2023 10:23 PM
In which case, you needn’t do anything since you’ll need a 2nd one anyway.
30 days from yesterday you’ll be back.
12-30-2023 10:20 PM
I am going there for 21 days. I will have to get another add on after the 15 days is up as it is.
12-30-2023 10:01 PM
Thank you very much.
12-30-2023 10:00 PM
before you go through the trouble of requesting it be reversed until closer to your departure, how long will you be in the US?
since they’re good for 15 days it may very well cover your time there depending on duration.
12-30-2023 09:57 PM
@Lorde Submit ticket with support and explain to them what happened and if they can revese it for you
send a private message To CS_Agents
