11-27-2019 04:40 PM - edited 01-05-2022 08:10 AM
11-27-2019 05:18 PM
@GmaGpa Make sure that the add-on has been added to your account. Access selfserve and check to make sure it appears under add-ons. If not, you need to purchase the add-on. Purchasing an add-on is a two step process. First you add the funds to your account then you must purchase the add-on.
11-27-2019 04:42 PM
More details are needed?
What is your plan?
Which add did you purchase?
Buying an add on is a 2 step process. Need to load funds and then purchase the add on.
11-27-2019 04:42 PM
