10-03-2023 06:42 PM
Do I have to go to Facebook somebody just like totally ignored my message even though a ticket was opened and there was somebody on the other end responding... I can promise you sitting in a Walmart parking lot on the USA side 3 1/2 hours from my house in Canada without any add-on that I purchased won't make for a very nice comment
10-03-2023 06:55 PM
And just so you're aware, @Sherrylb , we're just other customers like you here.
Making veiled comments such as those should be directed to Public Mobile staff.
We hear ya, though.
10-03-2023 06:51 PM
10-03-2023 06:48 PM
Which add on did you purchase? More details will get you more effective help here.
10-03-2023 06:45 PM
@Sherrylb- Does the add-on appear in you self serve account? Did you try to manually set the carrier?
10-03-2023 06:45 PM - edited 10-03-2023 06:46 PM
Do you see it in your list of add-ons? Do you see the payment in your balance? Are you connected to either T-Mobile or AT&T? Text and data should work fine. Talk is the tricky one that needs volte enabled for your device.
Adding - or able to switch to 2G GSM.
10-03-2023 06:45 PM
What have you tried? Are you connected to a US carrier? Is data roaming enabled?
Reboot your device.
