Add on help
11-27-2019 05:59 PM - edited 01-05-2022 08:10 AM
I purchased the $20.00 USA roaming talk and text and it seems that only the data is working.
Joining Public
11-28-2019 02:44 PM
Contact a moderator with this complicated issue by clicking ?, bottom right, and follow instructions.
11-28-2019 02:37 PM
@marilyn905 wrote:Hello everyone, I also am having the same issue with my phone, I purchased the 10day US Roaming Talk for $8 and renewed it over 2 days ago now Tuesday morning (26th) and my services still are not working, restarted phone. I found this topic @Moderator_Team please contact me I will be in USA for another 5months and I want to buy multiple blocks at a time last time the 10-day expired it took 24hours before it comes available again then I've waited over 2 days now making it over 3 days without service, PLEASE HELP ASAP 😞
@marilyn905 They won't contact you usually. You need to contact them. You need to click on the question mark on the lower right to open a ticket.
11-28-2019 02:34 PM
11-28-2019 08:24 AM
Still says I don't have the add on. 😩
talking to mods now
11-27-2019 08:22 PM
@Craig-Fisher I had to go sign up a friend. Did you find a solution? Message @CS_Agent ?
11-27-2019 07:28 PM
If you ahve selected the correct carrier, ATT, talk and text should work.
11-27-2019 06:37 PM
@Craig-Fisher wrote:It shows my ads ons as
- US roaming 250 MB Data (10-day)
- US Roaming- Unlimited Talk (10-day)
- US Roaming - Unlimited Text (10-day)
Looks like you've done everything right. You'll have to conatct moderator as suggested previously.
While waiting...try cycling phone off / on periodically. Try removing sim for a few minutes tehn reinstall and try again.
11-27-2019 06:33 PM
Things I would try, but not saying they will work.
Cycle Airplane Mode on/off, do a network reset, contact a moderator.
11-27-2019 06:32 PM
@hairbag1 wrote:@ChuckYeah...I wonder if the OP didn't buy the 1GB of US data Add-on for his $20...rather than the $20 Talk/Text/Data US Roaming Add-on.
It's possible. Probably should check that before trying anything else.
11-27-2019 06:31 PM
11-27-2019 06:30 PM - edited 11-27-2019 06:31 PM
@ChuckYeah...I wonder if the OP didn't mistakenly buy the 1GB of US data Add-on for his $20...rather than the $20 Talk/Text/Data US Roaming Add-on.
11-27-2019 06:22 PM
@Craig-Fisher wrote:I get the message that my plan doesn't supposed US Roaming where I have clearly paid and activated it
Yeah, I think the fact you have data means you must have purchased the add on. Can you go to your My Account and ensure you have the right one. You may have to contact @CS_Agent if T-mobile doesn't change your situation.
11-27-2019 06:20 PM - edited 11-27-2019 06:22 PM
Log into My Account / Data & Add-ons to see which Roaming Add-on you currently have. Let us know.
You're in US right now...right ?
11-27-2019 06:19 PM
iPhone. Have rebooted multiple times
11-27-2019 06:18 PM
11-27-2019 06:17 PM
@Craig-Fisher What kind of phone do you have? Apple or Android? Have you restarted your phone since your data connected?
11-27-2019 06:14 PM
@Craig-Fisher wrote:AT& T
land it shows AT & T on the phone
Try manually selecting T-mobile to see if that works. Let us know.
11-27-2019 06:05 PM
AT& T
11-27-2019 06:03 PM
@Craig-Fisher Are you connected to AT&T or T-mobile?
11-27-2019 06:03 PM
@Craig-Fisher wrote:It shows that the add on was purchased when I look at my add ones as well
Can you manually select the AT&T or T~Mobile networks?
11-27-2019 06:01 PM
