Add on Not added to plan
langdonarabians
I have the $15 plan and used all my minutes 100 this month. I purchased 500 min $5 add on 3 days ago and it has not started yet. PM tells me I am out of minutes. This purchase was done online logged into account and shows in account.
Plan renews in about 3 weeks, any idea how to get the 500 minutes talk I purchased added to account?
I did update to unlimited talk for next billing period.
Thanks in advance
Don
11 REPLIES 11
self solution removed
langdonarabians
Softtech
Thanks, I have two lines and the minutes have been added.
Don
@langdonarabians   as @dabr mentioned, you didn't do step 2, the actual purchase of the add-on , that's why you see only one line, the loading of the fund
Now, you can head to purchase add on and pick the 500 minutes add-on and buy.  PM will use the amount in the account for the purchase
dust2dust
Ok. So buying add-ons is messy. It always comes from a balance. You need to get that balance to pay for the add-on. That's where you are now. So then go into the purchasing screen and choose the add-on and use the money from your balance and you can buy the add-on.
langdonarabians
dust2dust
Then yes read the reply from dabr.
langdonarabians
Yes says balance is $5
@langdonarabians   you should be able to confirm your purchase in the My Account's Transaction History (https://selfserve.publicmobile.ca/Overview/payment/Payment-History/)  You should see 2 lines, one showing you loaded $5 and another line showing the purchase of the 500 mins add-on
Also, on the Overview Tab, My Data & add-ons, you should see it clearly showing the 500 mins add-on, do you see such a line?
dabr
@langdonarabians   Buying add-ons requires two steps, first add funds and then back to add-on page to purchase the applicable add-on.  Did you take the second step?
dust2dust
Sorry, balance of $5 in your Public account?
dust2dust
Is it showing under my data & add-ons in your Public account? Do you have a balance of $15?
