Add On
12-01-2018 02:56 PM - edited 01-05-2022 02:40 AM
12-01-2018 02:58 PM
Hi @tgra34. Did you perform the two step procedure to purchase the addon? If you only performed the first part, you will have the amount of the addon sitting in your account balance. If that's the case, just go back in and go through the steps again, and this time it will take the funds from the account and apply the add-on. If you already performed both parts, did you restart your phone? BTW, did you take talk/text/data? Is everything not working? Is your network selection set to automatic?
12-01-2018 02:58 PM
Roaming enabled?
12-01-2018 02:57 PM
@tgra34 wrote:Im in the US and i've added some add ons but my phone is still not working
Did you first add the money into your account and THEN also buy the add-on?
Then restart the phone. Turn on roaming for talk and data and scan for AT&T or T-Mobile.
