11-20-2023 12:51 AM
I have been to add the 15 day talk and text in the US to my plan and have been getting a message that the page is unavailable or under maintenance. I leave tomorrow morning and need availability.
11-20-2023 01:24 AM
once you get to US, log in to your account using local wifi...then buy the add-on you want. I used to load the add-on at Walmart in US using their local wifi. You likely have free wifi at your motel and most cafes have it too...you might just have to ask for their password.
Do you know if your cell is volte enabled yet ? Without it, you're limited to using 2G GSM for talk and it's going to be less than enjoyable experience...whereas with a volte enabled phone, you're going to be very satisfied with talk to most any US or Cdn number.
11-20-2023 01:04 AM
@NDesai- Well crap. A whole show shut down. Thanks for letting me know. (and the customer) Sometimes it does work when the main system is off. Yet another unannounced maintenance time. Thanks Public.
11-20-2023 12:59 AM
@dust2dust wrote:If you know your 4 digit account pin then you can buy it using the 611 service.
But you might want to verify if your phone has been enabled for volte here yet. That would calling a lot easier. Otherwise calling takes a little more work.
Tried 611 just now, the call just ends. I guess it's not usable when the maintenance is going on?
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
11-20-2023 12:57 AM
@racing13 Unfortunately, you can't buy an add-on when the maintenance is going on. Please check back early in the morning. If not, you can try buying from the US whenever you get on Wi-Fi connection.
11-20-2023 12:56 AM
